So, what is your final assesment of the pedal with the shielded wire now in place.
It's a high-gain pedal with a LOT of 201s. Unwanted noise is a byproduct of this design.
Of all the changes or adjustments made, these two seemed to yield the most "bang for the buck";
1.
Shielded cable - it mitigates EM amplification, which is needed with a circuit of this nature. I use 9v power supply cable. The insulator is delicate so you have to pay attention when soldering or it will melt well back into the length and you'll be dealing with a ground-short.
2.
Biasing - Two schools here. a) in accordance with the design criteria and given formulae, or b) turn those cute little thingys until it sounds good. I set mine to taste by setting all pots fully CW, trimmers at max, and backing them down one at a time. I started with T4 and worked back. There is a third biasing option; but it's difficult to source the correct chicken bones, and improper use could be disastrous!
The TMB is pretty weak in my opinion with little more nuance than a tone knob. For me, this was a bigger factor than the noise. If you can't effectively shape the "preamped" signal, what's the point?
I initially jumped in to offer another build to experiment, in light of
@Billyhank 's squeal. I am confident that it can be trimmed out.
As is typically the case; there are hidden gems of knowledge in this thread that I appreciate greatly. Thanks again to all!
EDIT: Almost forgot...someone on another thread suggested that naming pedals is a good idea. I named this one "Booger".
