Breadboarding -9v?
CheapSuitG
Here is my question of the day.
New to all of this, learning bread boarding and want to try a fuzz face, what is the -9v on the top? How do I go about doing that?
Circuits with PNP transistors usually use a positive ground because PNPs are biased the opposite way of NPNs: their base and collector need to be more negative than the emitter. Since the emitter is usually common between the input and output, we call that node the ground: the common potential to which all voltages in the circuit are referenced. A ground does not have to be negative, that is not a hard rule but just a convention. Negative ground simply happens to be more common these days, when NPN transistors are more frequently used than PNP.
Got it.
So I can use PNP germaniums with this, interesting......
The original uses pnp (ac128), you can flip the polarity of the 2 electro caps and use NPN with a normal centre negative supply if you want. Decent PNP GE transistors are just easier to come by these days 😂.
