breadboarding (tone bender MkII, MkI, fuzz face, big muff)
owlexifry
seemed like i was dragging @Stickman393 ’s thread out of scope (germanium transistor testing and leakage), so i’ve removed my comments and started a new thread here…
very recently i've just begun trying out breadboarding for the first time.
(wanted an excuse to test out some MP38 transistors i grabbed last year)
- first did an LPB-1. yep cool. it boosts. quite nicely too.
- next logical step was to try a fuzz face circuit.
- impatiently did a quick and dirty Hfe check with the DMM and picked x2 that looked stable and 'high enough' ?? (some bullshit creative logic going on here)
- biased Q1 collector to 0.7v (39K), Q2 to 4.5v (6.5K on trimmer).
result:
- fuck yeah. great sounds.
- seemed to be fuzzing nicely across the sweep of the gain
- sounded really good around 3'oclock to max on the fuzz/gain control.
So after @PedalBuilder pre-emptively crushed my dreams about the prospects of finding some real good NPN Ge, I thought yeah maybe I should actually measure these MP38s properly.
to measure gain and leakage i've been using this little veroboard circuit layout based on the rgkeen method
(http://www.geofex.com/article_folders/ffselect.htm)
so last night I did some R.G.Keening with my sample (n = 20)
- Hfe mostly around ~30.
- leakage all under 100 except for x2 (438uA, 655uA)
(i was gonna be helpful & type this up, but maybe it's a good idea to expose my potential errors)
well guess what i had running in Q1 and Q2:
Q1 - 1.082v / 1.217v : . 13.5 Hfe, 438uA leakage (#18)
Q2 - 0.108v / 0.403v : . 29.5 Hfe, 44uA leakage (#19)
so of the 2 / 20 that had significantly higher leakages, of course i picked one of them for Q1.
lol.
how is it possible that this sounded any good?
then it got more confounding.
so i thought ohh geez what if i used something in Q1 that isn't completely fucked (well 13.5hfe/438uA leak seemed pretty fucked to me...)
picked a couple different ones to try:
Q1 - #4 - 32.8 hfe/ 48uA
Q2 - #9 - 38.6 hfe/ 58uA
(re-checked bias at both collectors and got pretty much the same numbers as previously, Q1 0.73v / Q2 5.0v)
result:
- this actually sounded worse.
- more gated.
- had to pick harder to get 'the response'
- at low gain settings it almost sounded ring modulator-ish
- objectively a pretty good fuzz tone and sounded much the same i guess, but everything just felt like it was noticeably worse.
so i've just read this statement:
"for a transistor to function well in an original fuzz face circuit is not the correct gain, but rather the correct amount of leakage to bias the base."
honestly i hadn't paid a lot of attention to the voltage bias at Q1 base.
seems to me, since these MP38s are so low gain (~30), perhaps the leakage may not be enough in some to bias Q1 base properly?
(and maybe that's why that super leaky transistor in Q1 i first tried sounded alright...)
i did notice Q1 base was about 0.1xx V at one point (after inserting the 'properly measured' MP38s)
so, it looks like i need something in Q1 that will leak enough to get the bias at Q1 base up to at least 0.2V.
so to update from that:
- checked Q1, and yep, the base is idling at about 0.100V.
- this seemed too low. (target spec 0.2V)
- in an attempt to get Q1 bias voltage higher, last night after work i went ahead and tried every MP38 in Q1 to see what I could get.
- well, this sucked - half of them resulted in 0.08-0.09V, the other half about 0.1V, and a couple outliers.
- picked one with the highest base voltage at Q1 (0.118). Incidentally this was one of the lower gain (20 Hfe) MP38s.
- re-biased the collectors.
(had to increase R1 a fair bit to get Q1c bias voltage down - with 39K, it was idling @ 1.2V - too high)
- so i ended up with about 0.12V @Q1b, 0.75V @Q1c, ~4.5V @Q2c.
had time for a quick test this morning before leaving the house
[Q1 = ~20Hfe, Q2 = ~ 38Hfe]
(sorry no time for SM57+pre)
so acknowledging that the transistors are very low gain (20 / 38), much below the recommended values (70 / 120), it's interesting that this seems to be working at all.
i'm no fuzz connoisseur, i have no idea what i'm supposed to be looking for, all my guitars have humbuckers, but so far this sounds alright to me.
assuming it will probably sound better if i use transistors with higher gain? anything else i should be looking at?
Don't worry about the exact Q1 voltage. Q1 base voltage will be equal to Q1 Vbe since the emitter is grounded (0V). The Vbe will change some depending on how much current is flowing into (or out of, depending on NPN/PNP) the base, with more current making for a larger voltage drop, but it's not really something you can easily change by adjusting the circuit resistances - it requires a drastic change to go from ~0.1V to 0.2V. You often hear 0.3V for the nominal voltage drop in germanium, but with the low currents in the Fuzz Face (and most fuzz circuits), the Vbe is much more likely to be around 0.1V or even lower. 0.2V seems high. I have an original NKT275-loaded Arbiter FF here next to me and Q1's base measures at 0.096V at room temperature (and Q2C biases to around -5V and it sounds great).
Regarding this statement:
That's likely referring to current flowing into the base, rather than the base voltage. But the bias voltages depend on both (leakage and hfe), and Q1's specs have a much larger effect on the bias voltages than Q2.
I do wonder about your original Q1 measurements with the high leakage, it seems like those might be off. I think you'd have a difficult time getting that biased correctly, at least without drastic resistance changes, and I've got some doubts about whether it would sound good. When you swapped the transistors out for ones with more reasonable leakage, you said "(re-checked bias at both collectors and got pretty much the same numbers as previously, Q1 0.73v / Q2 5.0v)" - is that without adjusting the trimmers? If so, I definitely think the 13.5 Hfe, 438uA leakage measurement has to be off. Also, make sure you're driving it directly with passive pickups if you can. Any sort of buffer between your guitar and the FF input is likely to cover up some of the audible effects of using a very low hfe transistor in Q1.
I agree with Feral Feline that if it sounds good and works well, you don't really need to worry about it unless you're interested in the "why". Although high transistor leakage (and particularly Q1 leakage) does make the circuit more temperature-sensitive.
this is quite helpful to know.
thanks for writing all of that.
not sure what happened with those two outliers but those were the numbers i was getting using the RG Keen method. idk. everything else seems to be testing normally so i’m not too bothered..
i suspect the ‘bad sound’ i had experienced was most likely improper bias voltage(s). i was rushing. after i had another look and re-checked/adjust bias, it was sounding pretty good.
update:
since I had started with NPN germaniums, I was intending to compare with silicon transistors, so I picked and measured some.
- BC108B
i don't have my notes on these available right now, but i remember these all displayed much higher gain than i had anticipated. something like 250-300Hfe.
- 2SC1815
to my surprise these are the lowest gain silicon transistors i could find in my stash.
- 2N3904 seems to hover around 200-250.
- all my BC108Bs were around 250-300 (i think..)
- and then these 2SC1815s are all around 160-170...
anyway, since i was already measuring a handful of these for a superfuzz build, i picked a couple (159Hfe, 170Hfe) for the fuzz face.
results: (BC108B vs 2SC1815 vs MP38) - adjusting bias where necessary
BC108B:
- everyone suggests these for fuzz face circuits
- that's why i even bought a bag from tayda at all
- the ones i had are very high gain.
- not a bad sound, but sounded the most compressed, splatty, crunchy, and aggressive. perhaps too much.
MP38:
- Q1 ~20Hfe, Q2 38Hfe - way below specified gains.
- despite that, offers a full fat fuzz crunch, not as aggressive or crunchy as the silicons, noticeably smoother, less high end.
- i suspect i'd like these better if they were higher gain.
2SC1815:
- no one ever suggests these for fuzz circuits
- i bought these for Wilhelm Scream + Extreme Scream builds that I haven't done yet.
- i liked the sound of these the most.
- for lack of a better description, i guess this was a happy medium between the sounds of the BC108B & MP38 described above.
made an order a couple weeks ago, gonna be trying out some MP38A transistors soon.
hopefully these will actually be in or above the 90-110 Hfe range 🤞
TONE BENDER TOME
of course the next logical step was to try out a tone bender.
mkii seemed to have the most appeal.
i followed this schematic:
decided to try it first with x3 2SC1815 transistors.
- had a few confounding moments when i couldn't get any sound.
- great thing about breadboarding is the input/output jumpers serve as an instant audio probe.
- the rest of circuit was working fine, but Q1 wasn't giving any sound.
- Q1 base had almost zero bias voltage, and collector was idling at 8.9x v.
- then i looked at this 'deimos (legacy)' schematic and had an 'aha' moment...
correct me if i'm wrong:
i) the original schematic depends on Q1 having a certain amount of leakage from collector to base.
ii) with a modern silicon device (2SC1815), there is none of this leakage.
iii) so there needs to be a biasing resistor. which is why AionFx suggests the above with RX1.
with an added 1M5 resistor 'leaking current' from Q1 collector to base -> this solved everything for the 2SC1815.
(during troubleshooting, i swapped in a MP38 and it worked fine at Q1 without the 1M5 resistor, which was initially very confusing until i had the moment of clarity).
- followed these specs as close as i could:
- tried different transistors, as i did with the fuzz face (BC108B, 2SC1815, MP38), and with combinations, (e.g. BC108B-Q1, 2SC1815-Q2,Q3).
result:
- meh.
- yep it's got a lot of gain.
- nothing that pleasing or memorable about the fuzz.
- idk, this is not the fuzz for me.
- fuzz face shits bricks on this.
i can now see why there are 420 billion fuzz face-inspired variants as compared to only 1 billion tone bender mkii variants 😛
this time i’ve been playing around with a batch of x20 MP38A NPN Ge.
did some measuring with RG Keen method.
here’s a list of what i got:
the initial inspiration for even getting them was so i could try them out in an EQD Hoof circuit - after reading about the chuck bones mods in his thread.
since i had already breadboarded a triangle bmp it didn’t take much to change it to hoof specs, but i just left the tone circuit as it was. (and with a fixed volume control with a 30K/68K divider)
for Q2 and Q3, selected 54 + 61 hfe and dropped the collector resistors from 15K to 10K to get a better idle bias (3V seemed a bit low).
BC108 for Q1 and Q4.
sounds like this
currently waiting on a board to dry/cure, so on the weekend I decided to have a look at that stash of MP38A (in the post above) and maybe have another go at breadboarding a fuzz face.
found the stash, emptied it out and wtf...
i do not remember being this organized.
turns out i had individually bagged and labelled each one. this is like the reverse scenario of that Afroman song.
this was very motivating.
pretty much got straight into it and got a fuzz face cooking.
- started off with a top x4 selection of transistors for auditioning / assessing bias voltages.
- settled on a Q1 that actually had the perfect collector/bias voltages at stock schematic values (w/ trimmer at Q2 collector).
- and then with Q2, it was a close battle between x2 with the highest gains out of the lot.
*SPECS*
turns out the x2 transistors I selected and liked the most were also the leakiest.
Q1 - 54.2 hFE / 312 uA
Q2 - 87.8 hFE / 225 uA
the result:
OMFG.
yes.
this.
i get it now.
the last time i breadboarded a fuzz face (post #1), i wasn't really that excited about it.
it worked, did the fuzz thing, but it wasn't that remarkable. [to be fair, that was with lower gain MP38s with Q1 and Q2 @ 20 & 38 hfe]. neither were the silicon alternatives (BC108, meh..... perhaps i need to try some actual low gain silicon variants)
but this is glorious.
it actually does the thing with the guitar volume knob that everyone seems to foam at the mouth about..
well now i am one of them too.
with fuzz and volume controls dimed, i can it roll it right back to a pleasant crispy clean that has an odd but very pleasant pushed 'preampy' high-passed tone, and then all the way up to a wall of sound thick fuzz distortion. what a trick.
i had recently breadboarded the Ginormous Fuzz (Frost Giant Electronics Massif Fuzz), and was undecided about whether i was gonna build it or not, so I pulled that out to compare with this, and well.. I preferred the OG.
i got so excited, i even booted up DIYLC....
as a result, this is happening:
High leakage Fuzz Face = Tone Bender 1.5
You should get high voltage on Q2c around 8V.
And then you add the first stage and you have a TBII.
So you need leaky germaniums to understand what the fuss is all about, none of that silicon riff raff :)
well, with a trimpot on Q2c, I guess I could bounce between different bias settings for whichever flavour....
interesting when you say 'high leakage fuzz face'...
- where is the threshold for what is considered high leakage? or low leakage? or even normal?
i haven't really gathered a sample size large enough to classify.
what i do know is Q1 is basically fucked and won't bias properly if there isn't enough leakage.
(out of my batch of MP38A, the higher leakage units would bias a lot better than all the lower leakage units)
It's totally arbitrary but to me any value below 100uA is low leakage and any value above 200uA I consider high leakage. Usually if it's about 500uA the transistor will be almost unusable either because of excessive gating or excessive hiss.
In my experiments, biasing low-leakage transistors high (7-8V) resulted in a brighter tone but a loss of fuzz character, whereas high-leakage transistors naturally bias high, they sound brighter but they still have the fuzz quality, the ripping velcro kind of thing.
Keep in mind that I know nothing of biasing, I just listen to the circuit.
In a TB MKI, without leakage, Q1 doesn't work, and Q3 sounds dull a lower collector voltages. Artificially raising the voltage results in loss of treble and power. In fact, I still haven't managed to find the right 3 transistors to build a good MKI because there's always an issue (hiss, crappy not decay, loss of volume or gain, etc.)
I don't know how some builders are able to sell dozens of MKIs. I guess they have way more transistors than me or they use extra resistors to force leakage and I don't know how to do that.
This thread has been a pleasure to read through. Your Hoof just sounded amazing. Any audio of recent FF?
As soon as I get well from influenza I just NEED to breadboard another FF and muff. It should be considered as a universal human right porotocol there’s always some space, money and time for another ff + muff.
yeah this makes sense, cheers.
interesting, sounds like low leakage isn’t really the way to go here…
i struggled to get a Mk1 to sound good.
it does seem to be about finding suitable transistors..
i’ll have another go eventually.
go have a look at aionfx’s mki schematic and see what they’ve done there, it’s basically just a 1M5 or 2M2 from collector to base.
ay thanks 🤟🏻
nah not yet, i’ll probably do a demo after i build this ff on a board.
hell yes! that’s the spirit 💪🏻
following the success and satisfaction i’ve had playing with the fuzz face, i thought i might have a go at a mk1 tone bender.... 😅
i’d recently got a bag of GT404B NPN Ge, measured them up, with good gains (60-110) and relatively high leakage (160-200ish).
(although these values might be a little understated when i’m measuring them at around 15/16’c ambient temperature, house gets really cold in winter)
picked this schematic
with the available opinions online it appeared to me that mk1 requires even more leakage than fuzz face/1.5 seems to need, so i went with a set of GT404B with all at least 200uA leak.
well, even those - still too gated for my taste (Q3c ~8.5v), and Q2c couldn’t get lower than 6ish at full attack.
so i replaced Q2 with a higher gain and higher leak GT404B (98 / 257), and that got the attack range all sorted (down to 4.5/5v), and then i eventually conceded to putting in a bias resistor to Q3b (from 9V) 820K+1M trimpot to dial in the sustain however i needed it.
so at this point I was pretty sure I had everything biased close to where i want/needed it to be, and yet, it still didn't sound good to me.
I'm thinking this circuit probably isn't for me. either sola sound/gary hurst versions.
On initial testing I thought the lack of sustain due to poorly biased Q3c might be the main issue.. but I dunno, just not enjoying this fuzz.
so with that, i pulled the plug on Mk1 and grabbed a MkII schematic:
breadboarded the MkII exactly as above (for NPN), got it biased pretty easily and quickly with the same leak range GT404B NPN (~200+uA leak) i was using for the MkI and it immediately sounds awesome. MkII for the win!
listen to the MkII roar.
values measured at time of recording:
Q1C: 8.04V
Q2C: 0.335V
Q3C: 7.23V
Q1: 61.8 hFe/208uA, Q@: 70.2 hFe/202uA, Q3: 85.2hFe/204uA
i think i might be liking this more than the fuzz face i've been working on. damn.
time to do a layout.
The MKII is easy enough. I also have one on a breadboard that sounds similar and it also cleans up eventually byt more slowly than a FF.
The MKI OTOH is my white whale.
I noticed I need around 8V on Q3c or it won't sound right, and getting there with additional resistors sucks volume and high end (and it feels like cheating). And if you use transistors that are too leaky, it sounds like a$$.
I need a high gain high leakage unit there but don't have any. All my Germaniums seem to be under 100 for gain.
No idea what Seeker and JDC do for their MKI, maybe they simpy have more transistors than us.
my first attempt at mkii a few months ago didn’t go so well, and i reckon it’s 100% because the transistors i was using didn’t have enough leak (and gain probably), cos yeah it was gated and shitty.
but this time, i’ve got heaps more sustain and wiggle room in the bias/voltages and now its cooking.
i hear what you’re saying.
sounds like getting ‘correct bias’ with adequate leakage is the best way to get there.
and while i respect that mk1 requires a bit of careful selection and skill, i’m starting to believe that maybe mk1 just isn’t that good.
every demo i hear between mk1 and mkII, its usually a case of mk1 sounds a bit fucky and the mkII sounds great.
most likely.
idk.
i’m gonna go with there’s probably a good reason why the mk1 got canned and the mk1.5 and mkii took its place hahah
most likely.
idk.
I think the MKI might be the best fuzz sound ever but it's an on or off pedal, no dynamics.
I'm actually happy playing my out of phase Fenders into a Fuzz Face. It sounds like a chainsaw and close to an MKI with a wah on. All I need is a new tone pot, linear or rev log, so I can do the wah sweep with the pinky.
well, someone has to love it.
just went through some more demos and i’m hearing a common theme from this family of Mk1/Zonk:
- somewhat gated
- overly saggy
- that ‘velcro’ / stickyness descriptor
- ducking under power chord / big low end.
none of which are things i look for or enjoy in a fuzz.
hahah great idea, alright - you are now required to record and share a demonstration of this ludicrous technique
Owlexifry, this thread rocks! 🪨🤘🥌
Good reading, I should follow suit and work up a MKI TB, well, everything really.
ay cheers 🤘
actually, save yourself a tonne of bullshit and disappointment - skip the MkI - and do a MkII or 1.5/fuzz face instead. so much more fun.
You mentioned "big low end" for the MkI/Zonk. I've never built either, but I have read the Zonk cuts lows...
I'm always looking to retain lows (bigmouth bass player here); any more experience/thoughts on the Zonk?
if you want big low end - you want the fuzz face/1.5 - it will handle and retain it.
MkII does cut some lows.
my experience with MkI is that it just lays down on the train tracks begging for the sweet mercy of death at the sight of any low end content.
if you've ever seen that description regarding a distortion tone/circuit having that "amp on verge of imminent explosion/meltdown" - well to me, that perfectly describes MkI.
i have a feeling the negative feedback loop in MkII/1.5/fuzz face is a big part of why those circuits rock so hard.
