BS170 transistors for Prince Albert build
Mark
I was building a Lemonade pedal and found that the new 2N5457 FET’s were no good and I would need NOS FETs for the build. The NOS 2N5457 worked Luke’s charm.
I was wondering if the BS170 transistors have and issues the 2N5457 FETs?
Thanks for your assistance.
Regards
Mark
As far as I know, Mosfets like the BS170 aren't counterfeited, thus usually work fine. If you want a second option, also order 2N7000s, but you need to flip them 180° due to the flipped pinout.
Regarding 2N5457, you can get the SMD version of those and through hole adapter boards. The smd ones are usually fine.
Thanks for your replies, they were very helpful.
I didn’t want to go through the nonsense I did with the FET’s.
Regards
Mark
