Feral Feline
Diggin' the Bredi Deverboard, Buddy!
Yea. It has a similar topology with some extra goodies thrown in there. I'm sure with your knowledge you can make this better. It was a fun build regardless.Kinda resembles a Fuzzrite. Since you're blending out-of-phase signals, you should get some octave-up tones.
@Chuck D. Bones how can you tell just by looking at the schematic that the signals would be out of phase? What's the giveaway here?
That makes sense to meFor my own edification I will try to reason this out. The first transistor flips the phase, then you split the signal into A & B.
A goes through another transistor flipping the phase of A again, so it's in phase with the original dry signal, but B is still flipped out of phase.
Add a transistor buffer/boost to B that flips B's phase before you mix A and B back together and you should be okay.
maybe have the extra transistor as a switch-in or switch out to have the option of blending two out of phase signals.That makes sense to me
I have that exact wire kit. I was breadboarding an expanded version of my Dumesday Fuzz yesterday trying to figure out a way to turn a no-knob fuzz into a four knob fuzz (I mean, adding knobs is easy— figuring out what kind of controls is the tricky part. Volume? Duh. Fuzz? Idk… it’s got great cleanup with the guitar vol, and doesn’t sound as good just lowering the gain the usual way. Voltage starve? Probably. Tone? But what kind of tone stack— can’t decide. Some sort of envelope controlled q2 bias? Maybe, but maybe too weird) and those jumper wires came in handy as usualMore a PSA than anything else to the aspiring breadboard baker, jumper wires make a huge difference. The problem is that a lot of the more flexible wires are either way too long or way too short and can make your layouts quite messy. So, naturally, I started making my own jumpers out of some hookup wire in various sizes and color coordinated. This turned out to be a very tedious and time consuming process and I think I made 1-2 dozen in about an hour by more or less eyeballing the different sizes I needed. A few days ago I bit the bullet and dropped $12 for some hookup wire based jumpers and these are a godsend! Sometimes I'm waaaay too cheap in this hobby thinking I can just DIY everything. $12 saves me hours of tedious work with no circuit built as a result. The small ones in the bottom right corner will be used all the time based on how I layout my boards. The large ones I'm probably not going to use, but you never know.
I still need to pull the trigger on some breadboard mountable switches which will clean up the layouts even more.
