Kroars
I see there are a few folks on here that have had great success with the GPCB Buff n Blend circuit and I’m hoping someone could shed some light on this. I’m sure I’ve overlooked something.
I’ve built a Univox Super Fuzz and want to add a clean blend to it. Super Fuzz tested perfectly. Wired the Buff n Blend up to it (positive and negative from all three boards temporarily wired at dc jack) and I only get clean signal when I turn the Blend knob towards clean. When I turn it towards the Super Fuzz, it gets very quiet and I can’t hear the SF effect. I thought perhaps the SF was inverted, so I built a Stage 3 booster (as GPCB suggests for phase issues) and wired it in series with the Super Fuzz -same problem.
I have the send of the BnB going to the input of the SF, the output of the SF going to the return of the BnB. Then I tried the inserting the Stage 3 booster into the mix: BnB send going to input of the SF, output of the SF going to the input of the Stage 3 and output of the Stage 3 going into the return of the BnB. Still nothing.
Ive installed the J113 and both caps in the footswitch side of the BnB board due to space constraints. Although, both are installed in correct orientation. I can add a few more photos when I get home if needs be. I don’t suppose anyone can help point me in the correct direction.
Thank you kindly.
Thank you kindly.
