yeah that one’s tricky, since it’s reverb INTO fuzz, so how think about how would you want the tails to work. Normally, on bypass with tails, the signal still passes through the pedal, but the input of the delay or reverb is muted. Since the dry path of most delay pedals is clean (just goes through op amps), this works fine as a bypass signal. In this case the dry (non-reverb path) goes through fuzz, so this method wouldn’t work. You could probably do something cool depending what you want (like have one stomp kill the reverb with tails, with fuzz still on, and then another stomp switch to true bypass the entire pedal.
