Cool. I see that now. Probably not a bad idea to check the schematic first... I guess I thought there was a hard and fast rule on these types of things. Thanks again!!!
It all depends how the pot/trimmer is set up. If it's set up as a variable resistor you can jump it from 1-3 generally, if it's set up as a voltage divider you need to do the 1-2 and 2-3 resistor jumper thing.
