squirrelboy
Yeah, it’s weird. The pedal works fine for approximately 30 seconds each time I unplug and plug the power back in, and then after 30 seconds it seems like the LFO stops oscillating.
Any ideas?
Any ideas?
Could this be caused by having the wrong value for a resistor?Sounds like you might have an op amp that's missing an input bias resistor. Can work for a while until the input DC-drifts into one of the rails.
I just checked the voltage at each pin on the 4558s. I got the following on both:It would have to be a far higher value than what is called for. Such as 10M instead of 100k. Best to just take a voltmeter and probe op-amp pins that should be sitting at Vref.
Yes those look right. Typically you’d want your com probe on ground looks like you got it reversed.I just checked the voltage at each pin on the 4558s. I got the following on both:
1. -4.37
2. -4.37
3. -4.37
4. 0
5. -8.86
6. -4.37
7. -4.37
8. -4.37
Do those values seem correct?
No they don't. Pin 8 is Vcc and you should have around 9V on it. Or since you measured it with your probes backward, you should get about - 9v. Also, pin5 should have about 4.5V.Yes those look right. Typically you’d want your com probe on ground looks like you got it reversed.
Ok I’m going to check again to see if I have a wrong resistor value.No they don't. Pin 8 is Vcc and you should have around 9V on it. Or since you measured it with your probes backward, you should get about - 9v. Also, pin5 should have about 4.5V.
Also, is there a schematic available anywhere for this pedal?
Yea sorry in my head I just fixed that he made pin 5 pin 8No they don't. Pin 8 is Vcc and you should have around 9V on it. Or since you measured it with your probes backward, you should get about - 9v. Also, pin5 should have
Yes I am using a 2N5807 instead of a BC560C. The 5807 has a reverse pin orientation.This guy backwards?
Oooo I am going to check this. Thanks!I don't know how up to date the info I have is but what value should R50 be in the parts list I've got it's 150K on your pcb it's 470K that looks to be part of the LFO circuit
I didn't check beyond finding that so if you haven't already check all component values and orientation are correct
You could use the BF2 schematic here to give you an idea of the circuit layout obviously the component reference designators won't be the same and I'd imagine it won't have the FET bypass switching
Boss BF-2 flanger guitar pedal schematic diagram
The schematic diagram of Boss BF-2 flanger guitar pedalwww.hobby-hour.com
Check your voltage regulator isn't getting hot I know the L78L05 has internal thermal shut down if it gets too hot and therefore shuts down and cuts out
