Lovely build, the internal trimmer is for biasing the BBD's. If you have chorusing sounds at 12 then consider yourself fortunate!
This particular chorus has a very small range on the trimmer where you get chorusing. You might want to slightly fiddle with it left and right and see if you get stronger chorusing.
Looks incredible as usual! I’m a big fan of the vibrato mode on the Caesar with the blend turned all the way up.
Have you posted here about your etching process? I’ve been etching some little nameplates, but I haven’t tried an enclosure. I’d love to know what you’re using for etchant/ resist, and what you’re using to get the dark contrast. Whatever you’re doing, you’re getting great results.
This is how I etch pedal enclosures; Step 1: The enclosure will look something like this to begin with; Note: I have found that the Eddystone line of Hammond enclosures are better for etching and...
diy-guitar-effects.tumblr.com
There are two key things that allow me to get more contrast
Shiny enclosures
I do a LOT of sanding before I etch to get the enclosure super shiny.
I pony up for the more expensive "Pro" enclosures from Stomp Box Parts
AVOID the crappy, pitted ones from Tayda which are fine for painting but are kind of ridiculously impractical for etching in my opinion.
Tinting the etch.
As a final step, I fill the etch with black lacquer gooby with the lacquer crayon in the photo below. I sometimes let it dry overnight, then using 7000 grit sandpaper to reveal the hilights while trying to keep as much as possible in the etched parts.
It's even more time consuming and brutally annoying than it sounds...
Always happy to share help out if you want more thoughts.
You can also think about the children of your children's children. Shouldn't you write some wise and enigmatic words inside the enclosure, for the future generations ?
