Hey all! New to the forum but I’ve built a few pedals in the past. Mainly wah wahs with a guy who owned his own company that made them, so plenty of room to run wires between switches and pots!
This is the first full build I’ve done with everything mounted directly to the PCB and I thought I did a pretty good job with lining up the drilling template but now that I’ve test mounted everything, I have found that i overestimated my skill level at that point. Everything is a bit low by a few millimeters which prevents the pots to “lock in” to their spots on the pcb without bumping into the switch.
My question here, I have a ton of hookup wire and heat shrink available, can I just solder some of it too the lugs on the pots/switches and run it into the pcb spots? Anyone see any huge issue with doing that?
Or do I need to scrap the enclosure and try again?
