Its two PCB's from Effectpedalkits.com I picked them over PedalPCB for this pedal because his are more compact and allow for offboard potentiometer wiring. I just wish he had included a couple extra ground pads so I'm not struggling to fit multiple wires through one pad. The LED's I have in the diagram I posted, they're the little grey circles.Looks ok to me. It's pretty much this plus the LEDs. https://wiki.pedalpcb.com/wiki/2-in-1_Pedal_Wiring Are you building stripboard or other PCB for the two effects?
No, LED's on these are off the board.I figured that for the LEDs. Does the board not come with them ready to solder in?
Yep I've got them In front of the LEDs, just didn't feel like putting them in the diagram. Also good suggestion with the Ground wires.Double up the GND connection at the switch rather than the board pad. Also ensure you have CLRs for the LEDs.
I would use a 3pdt breakout but the holes in my 2-in-1 enclosure for the switches are so close to the edges that they won't allow space for one.Heads-up- the FuzzDog 3pdt boards align with these, and have a spot for board mounted LED
Also came to say this.
Those particular 3pdt boards are the same width as the switch baseI would use a 3pdt breakout but the holes in my 2-in-1 enclosure for the switches are so close to the edges that they won't allow space for one.
