F FancyEspresso Member Aug 17, 2020 #1 looking at the build guide its wired a little different than the bypass. can i use the relay module? and if so are there any changes that must be made?
Nostradoomus Well-known member Aug 17, 2020 #2 It can be done! https://forum.pedalpcb.com/threads/leprechaun-with-relay-boards.1016/ maybe @p_wats or the Man Himself can chime in on the wiring.
F FancyEspresso Member Aug 17, 2020 #3 great didnt even see this thread! hopefully someone can drop some knowledge on me as to how its done!
p_wats Well-known member Aug 17, 2020 #4 Here are the instructions I received that worked perfectly: Looking at the pads for the Magic footswitch (the four on the right of the PCB), we'll label them 1 - 4 (from left to right)Make these connections to the Relay PCB:1 - GND2 - SW3 - OUT4 - JACK OUTPUT (pad on far right of Relay PCB)
F FancyEspresso Member Aug 17, 2020 #5 Killer!! thank you so much! Now i just have to worry about cramming everything inside ?
p_wats Well-known member Aug 17, 2020 #6 FancyEspresso said: Killer!! thank you so much! Now i just have to worry about cramming everything inside ? Click to expand... If I can do it, you can do it!
