Doing some cleaning today and found this buried in a box. I think it's about 5 years old. If anyone can help me identify I would really appreciate it. Thanks!
For what its worth, on the pedalpcb store if you type in the searchbox “pcb019” (as an example) what it is will come up. I forget if its only in the dropdown suggestions or if you can actually hit search. I have to do this all the time myself lol
When I type "PCB019" into the store's search-bar I get the PERSICA FUZZ (Frantone Peach Fuzz),
NOT the ADHD.
To the best of my knowledge, Robert will change the revision number (date/version), but does not recycle PCB SKU-numbers — at least, I've never come across any that've been recycled for a different circuit.
The current ADHD PCB# should be the same as the old — PCB542. https://www.pedalpcb.com/product/pcb542/
You have to click an/the item from the dropdown menu; mm just tried it and now if there's only one item you can hit "return" — this is different from how it used to be, as I once had a problem with searching for SKU#s and Robert sorted it out for me.
