Can someone help me identify this PCB?
ilgfo
Doing some cleaning today and found this buried in a box. I think it's about 5 years old. If anyone can help me identify I would really appreciate it. Thanks!
The PCB is marked "PCB019"
That was quick! Thank you!!
For what its worth, on the pedalpcb store if you type in the searchbox “pcb019” (as an example) what it is will come up. I forget if its only in the dropdown suggestions or if you can actually hit search. I have to do this all the time myself lol
When I type "PCB019" into the store's search-bar I get the PERSICA FUZZ (Frantone Peach Fuzz),
NOT the ADHD.
To the best of my knowledge, Robert will change the revision number (date/version), but does not recycle PCB SKU-numbers — at least, I've never come across any that've been recycled for a different circuit.
The current ADHD PCB# should be the same as the old — PCB542. https://www.pedalpcb.com/product/pcb542/
You have to click an/the item from the dropdown menu; mm just tried it and now if there's only one item you can hit "return" — this is different from how it used to be, as I once had a problem with searching for SKU#s and Robert sorted it out for me.
