soothsayer86
I completed my build (second ever) and plugged everything in. I got sound when in bypass but nothing happened when I switched the pedal on. I thought maybe I had put the LED in the wrong way so I switched that around and tested again and that time I had signal through the pedal both in by pass and when engaged, but the LED didnt light and there was no effect present. I am unfortunately waiting on my multimeter to arrive so I am unable to use that to test at the moment. I am just wondering if there is an obvious issue with my build.
Also, now that I am not sure which way my LED actually is in, I was going to start with a fresh one but all I have is a two color LED with three legs. Is there any way to use this one as a single color by using only two of the legs?
Thanks in advance.
Thanks in advance.
![IMG_4279.jpg IMG_4279.jpg](https://forum.pedalpcb.com/data/attachments/4/4118-33ad325d91b6940644c83da37c5462a6.jpg)
![IMG_4285.jpg IMG_4285.jpg](https://forum.pedalpcb.com/data/attachments/4/4115-e6cc5c13eb261c909e3e4f0be7dbf7d3.jpg)
![IMG_4282.jpg IMG_4282.jpg](https://forum.pedalpcb.com/data/attachments/4/4116-ba624b25d5735b18b1d26804fbafae4e.jpg)
![IMG_4281.jpg IMG_4281.jpg](https://forum.pedalpcb.com/data/attachments/4/4117-a57ed73d939d4c776c4ab52ca3f52002.jpg)
