CDXL Reissue Reverse switch sounding thin
maerlma
Hello, I just finished up a CDXL Reissue Envelope Filter. It sounds great in the normal mode where the sound is more of wah rocking from back to front sound. However; on the reverse mode it sounds a bit thin, like I might have an iffy joint some where. I don't have pics right now, but I can post some tomorrow, but I was hoping someone might point in the direction to start looking. I've been looking at the schematic for a while now, but admittedly get a bit
just to close the loop on this, I checked r26, r13 and r14 (soldering and values). I also check the switch soldering as well, and that all seemed good. Turns out the trimpots in this circuit are fairly sensitive and need to be adjusted to taste, which is particularly true when in the reverse position.
