coltonius
Aloha. I just finished the Celsius Preamp last night, and it's a lot of fun with plenty of gain (volume) on tap! Preamps aren't typically my thing, but I've heard plenty of great feedback on the PastFX and Triungulo versions and decided to take a whack at it.
The problem is, there's a ton off white noise that persists in just about every situation:
As you can see below it's a pretty straightforward build. The astute among you may notice a few values that seem off, but I've cleverly split some values I didn't have with a parallel resistor under the board (eg., two 3k in parallel to create a 1.5k).
So the big questions are:
Is this normal behavior for the build? I understand there's a metric ton of volume and gain available.
Is there any way it can be mitigated?
Thanks in advance for the help, guys.
- onboard Gain knob in any position (worse at higher settings)
- no guitar plugged in
- guitar plugged in, guitar Volume all the way down
- toggle up or down (with or without transistor inline)
- with or without buffer in front (for the purposes of this test I used both a JFET buffer and the buffered bypass in a Centaur clone)
- swapped IC
