SOLVED Cepheid Chorus no effect (TB and LEDs working)
MrTambourineMat
Hello, I just finished to build a Cepheid chorus, I bought a kit from DasMusikding because I wasn’t able to buy just the PCB (I’m from Europe), so I presume that the MN3007 is original.
True bypass and both LEDs work fine, but when I turn the effect on it does nothing, I’ve tried to turn the trimpot and if I got too much off the center, both clockwise and CCW, I stop hearing the clean sound and start to hear something that seems a white noise with chorus.
I’ve double checked the board and everything seems to be fine. Any tip?
Thank you
Solution
I'm not sure the V3102 and the MN3007 will work together. I could be wrong. I used a V3102/v3207 in mine.
3007 needs a 3101
Thank you all for the answers.
1) I’ve checked all transistors and to me they seems to be in the right position. All “facing” down with this sequence of pin: EBC.
2) Checked out voltages and the MN3007 has like 8.7V, shouldn’t it be between 10-15V? (I’m powering up the pedal with a 9V power supply)
P.s. Maybe I’ll try to clean again the bottom part of the PCB, can I use isopropyl alcohol right?
Sorry about the transistor comment. There is a trace near the bottom right transistor I thought was the transistor outline.
Here there are all the measurements:
TL022CP:
  1. Variable (1-7V)
  2. 1/2 Vcc (4.3V) - not stable
  3. Variable (1-5V)
  4. 0V
  5. 1/2 Vcc (4.3V) - not stable
  6. 2.76V - stable
  7. Variable (2-6V)
  8. Vcc (8.71V)
MN3007:
  1. 8.71V
  2. 4.23V
  3. 3.70V
  4. 8.15V
  5. 0V
  6. 4.21V
  7. 6.23V
  8. 6.20V
V3102D:
  1. 8.71V
  2. 4.23V
  3. 0V
  4. 4.23V
  5. 0.15V
  6. 8.53V
  7. 2.80V - not stable
  8. 8.53V
RC4558P:
  1. 4.43V
  2. 4.43V
  3. 4.34V
  4. 0V
  5. 4.38V
  6. 4.44V
  7. 4.44V
  8. 8.83V
3007 needs a 3101
Solution
Ouch, thank you!
I didn’t notice that, I’m gonna order that clock and I’ll let you know. Thank you so much.
Cabintech has a new-production 3101 replacement. I don't know about their availability in Europe.
