Cepheid Chorus Stereo?
Magous
Has anyone build a stereo Cepheid Chorus? (With two simple mono jacks, dry to one, modulated to the other?) what would be the best way to do that? Could R34 be lined out to a separate IC / Jack?
I like the idea. I think that makes sense. You could even do it on a switched jack. So that way it still works as the mono chorus, but when you plug into the dry jack the effect output is 100% wet.
I plan on doing almost the same with the Caesar. My plan right now is to grab one of these Buffer/Inverters. So I could do dry/wet out, and also the original and inverted signal for a wider stereo spread.
That’s essentially what the CH-1 does…
This is the stereo chorus I keep coming back to, @jcpst but a wider stereo field would be cool. Doing this with a CE-2B with the cap that’s different from the CE-2 on a switch would be a cool mod as well.
That’s so awesome. It’s sounds cool as hell!
