Coda
I build the Cephid Chorus a month ago or so. I noticed almost as soon as I turned it on that it popped when engaged. Reading around a bit, I have discovered many possible causes and solutions. My question: when the pedal is powered off, I measure about 0.028v, and when I engage the pedal it drops to 0.001v. This is most likely due to a leaky electrolytic, correct? Will a small value resistor from output to ground solve the issue?
