Ginsly
I have a strange situation where in certain fuzz circuits, my single coil guitars are kinda overloading the input more than those with humbuckers. The opposite is usually true for me, and I drastically lowered the pickups on one of the humbucker-equipped guitars years ago and it helped a lot. The other one must have low/medium output humbuckers because the pickup height is pretty "normal".
I lowered the Strat pickups to see if the same thing would happen, but it didn't help much. Haven't messed with the cheapo tele yet, which is also kinda turning to mush through certain fuzzes. I'm using the Middle/Bridge position on the Strat and Middle position on the tele. The buzz is ungodly in any of the other positions.
What do you like to do in this situation? Other than fiddling with the pickup height I breadboarded some of these things:
- series resistor at input. Tried 1K-100K. The higher value helped a bit, but totally zapped the fuzz. Tried this as a "pre-gain" pot too, but just a rheostat - didn't connect the pot to ground (does that matter..? I've seen differing opinions).
- lowered input cap. I expected this to help more, but it mostly just made the fuzz tinnier.
I'm not terribly surprised that the pre-gain resistance didn't help much, as just turning my strat's volume knob down a bit didn't really sound great either.
What else should I try? Seems like this is a pretty standard issue people have when switching between guitars, but I'm not sure how best to deal with it when creating a circuit layout.
