Synchrony Pedalworks
I have a huge packet of zener diodes, but I failed to look and see if I have 2V7 diodes. Unfortunately, my pack doesn't have that value. In the Cetus, the 2V7 diodes are used in series with another valued Zener diode. I believe that they are being used as clippers. One is paired with a 3V6 and the other paired with 5V1. From what I briefly searched, it may be possible to use different values that add to a similar value of the sum of the original two diodes. The only difference is the forward voltage of the forward facing diode does enter the equation.
If I changed the value of the two diodes to equal the sum of the original schematic, would it alter the pedal significantly?
I may test the idea with the breadboard, but wanted to see if anyone had any other thoughts?
