Do you have guitar signal thru, or just noise?ok, done that. Now its a little more like really loud white noise than a squeal, but still there. Components were all tested other than the IC's. I don't know how to test them. I can try swapping them out?
Out of hundreds of ICs I've purchased from Tayda I think I've only had one batch of bad chips and they noticed it before I did. It could be luck of the draw and you got one bad one. Either way it's something to try since some chips can be noisier than others.The charge pumps are from tayda, I thought they would be legit, don't often use those ones though. Will the 1044 work in this circuit? I think I have some lying around
