Chauffeur Overdrive - caps in output
fontoponto
Hi fellow solder melters,
does anyone have an explanation the reason for the unusual caps in the output section and how they affect the signal?
back to back like that in series and backwards from one another, those two polarized 100uF capacitors form a 50uF nonpolarized capacitor.
It's DC decoupling (blocking DC so that only the AC signal passes), and I think it's a little overkill (lots of circuits get by with like 1uF or less), but I also think overkill is sort of de rigueur for this circuit.
In another forum there is a discussion about this. Beside the decoupling the cap and the pull-down resistor are forming a high pass filter which might be useless in this case.
I was wondering if some one has more insight about why it is designed like that.
A bunch of design decisions in the circuit are just stupidly redundant or overdone. But maybe the goal was exactly that.
50µF + 0.47µF in series = 0.46562µF
Is there some kind of "tube-like sag" by having series capacitors "fill up"? 😸
If not, then stick in a 470n film cap and be done with it. Yeesh.
