do I have the V1 board?
Hi all
First PPCB build, the lovely Chop Shop.
Biased the J201 without problems thanks to the threads in here, sounds great, boxed it up and it pops quite loudly when pushing the 3pdt.
Anything obvious that I'm missing? R1 should be the pull down resistor right? Looks fine to me
If it's DC offset coming from your amp or your computer interface or whatever, you can try blocking it at the source. A dead/dying preamp tube in V1, for example, can be a bummer - could be an easy fix if that's the case. Lehle make a little utility box for just this purpose, you could try rolling your own and placing it between different part of your signal chain. Alternately, you could add always-on buffers to both ends of the pedalboard/etc and see if that solves the issue?People smarter than me. If this is the case, is there anything design-wise in a pedal we can do to avoid it? Like are certain designs more or less likely to be affected by this? Or is it 100% the amps fault?
That was it. Thanks a lot! I don't know why I didn't think about it, since it's the same thing I did to get rid of the pop in my EHX Bad StoneV1 didn't have a pulldown resistor on the output.
It might be worth adding a 10K resistor from the OUT pad to GND.
ah yes thanks, got it. In the end I added it on the 3pdt but on the pcb would've been wiserIt's the V1 circuit altogether, not the PCB specifically. In hindsight it probably should have been added anyway.
I'd add the resistor at the PCB like your first picture to avoid heating the 3PDT lugs any more than necessary.
I'm not sure that this is a common issue with the build or anything like that, it's just the first thing that came to mind after reading your problem.
I did try it when I first built it but it didn't change the pop unfortunatelyYou might start by disconnecting the LED and seeing if the pop goes away.
Is there any plan to release a board of the v2 with the tone switch ?V1 didn't have a pulldown resistor on the output.
Well you just made my day !Yep. Prototype is on the way.
I’ve seen a what was supposed a schematic of v2 - the sag was completely different and only acting on one stage (like the ss/bs mini) - is that right from your version?Yep. Prototype is on the way.
Nice! What kind of timeline are we talking? Was about to order v1, but I'll wait for the new one then!Yep. Prototype is on the way.
Awesome! I'll see if Musikding will offer an updated kit anytime soon, otherwise I'll order directV1 is gone, V2 will be available in the next few days.
