rwl
- Build Rating
- 4.00 star(s)
This is a a report on the Chop Shop OD, based on the Fairfield Barbershop. This pedal showed up on some pots in the original Top Five thread and is pretty consistently recommended on this forum, so I wanted to see what all the fuss was about.
Inspiration
I was originally going to give this pedal a Barbet theme - an obvious play on the Barbershop name (e.g. something with this bad boy - Barbets are tropical finchlike birds). The bird is dope but I was really struggling with the background, because I wanted to give it a barbershop pole kind of look, and the whole thing felt really garish.
Then I saw a "request" for a scrub jay design in this thread, and figured that there's some kind of overlap there. Maybe it's more in my head but I just had this image of a barber sweeping up hair from his shop. Scrub Jays are visible in the pacific northwest, but it's more of a rarity - whenever we see them rather than the more typical Stellar's Jays, we stop and take a look. I like them, but perhaps they're my third favorite jay (after Stellar's Jays and Blue Jays). I do like that Jays in general are very smart birds - they're corvids, so they're in the same family as crows and ravens.
But then Scrub Jay theme was also a bit of a struggle for me. I knew I wanted the pun of the bird to actually be "scrubbing" something, so it was a given it would be holding a mop (the Scrub Jay is named after the scrub ecosystem). Then I started feeling I'd like a coniferous forest background, but it all felt cluttered and I just wasn't inspired. That design looked something like this (not final, I would have improved contrast a bit):
Pretty, but more of a poster than a pedal and I've started to steer clear of that concept - not avoiding it 100%, but definitely leaning more into "pedal" aesthetics that feature a more prominent central image.
Then it hit me, the jay needs to be scrubbing something. Why not lean into the messiness and dirt of pedals? So I went with the stained kind of background, left the jay on its branch with the mop, and I'm very happy with it. It's a simpler layout and makes the scrubbing theme more obvious. There's a UV print across the entire front, which I would probably avoid in the future, but I wasn't sure whether the stains would blend poorly with the Tayda background I chose (cream).
The Build
It's an easy build (not many parts, easily obtainable). I used Aion's J201 through-hole adapters here, but were I to build this again, I'd just use the SMD J201 pads that are on the board (as I have with some subsequent circuits). Soldering SMD transistors isn't my favorite thing, but they're not that bad, cheaper, and can be obtained from the more usual stores.
I really struggled with biasing the pedal though. Apparently Fairfield (and PPCB) reversed the function of the sag knob between pedal versions, so old instructions on the forum got out of date. I think this was also the first time I biased a pedal by measuring actual voltage with a DMM. Plus it was hard to know what this pedal "should" sound like at different settings. For that reason, the build was frustrating, but at least I didn't have to do much disassembling or debugging beyond figuring out how to bias.
I detailed my investigation into biasing in this thread, where @Fish encountered the same problem at the exact same time that I did, and @temol provided some helpful advice.
It's not a particularly noisy pedal, but I figured I'd give this one the deluxe treatment and use shielded wires for the input and output since it's a favorite. It looks messier since they don't stay put when bent, but it does decrease background noise.
The Pedal
I love it. It's currently in my "top five." I've played with it more since reboxing it in a printed enclosure and I like the natural overdrive setting. But to my unsophisticated ears that doesn't necessarily distinguish the pedal from other overdrives. What I like to use it for is to clean up other overdrives, with some of the knobs are rolled back. It's subtle but noticeable. My favorites are with the Paragon and the Glory Hole. It sounds great and if you turn it off and listen to those pedals on your own it immediately sounds worse. And if you come back with fresh ears and start playing those pedals on their own again, they sound great... but turn on the Chop Shop and they sound amazing again.
I think sometimes a second overdrive that "cleans up" the ones in front of it can end up being kinda harsh or trebly or grating after a few minutes, but I haven't noticed that with the Chop Shop.
Firsts
Pedal rating: 5/5
Inspiration
The Build
The Pedal
Firsts
First time biasing with DMM
First theme "requested" by a forum member (@Erik S )
Pedal rating: 5/5
