Clipping Switch Direction
I just checked mine and if you are looking at the front of the pedal, right is 1N4148, middle is none, and left is LEDs
Ok so I had it opposite, thanks. Just for my own knowledge, how is that illustrated reading the schematic? I know I’ve come here for this type of question before.
Also, what do you think of this one? I feel like I searched “Felix” here for information and didn’t find much.
It isn't really indicated in the schematic as such (there are 1-2-3 designations though). It depends on the footprint they used when laying it out. Typically pad 1 on a switch is the square pad you see on the board but this isn't always the case. It's best to just look for the traces on the actual board. Just remember the switch throws opposite to make contact, and it's flipped around when you have it mounted facing up.
It's not confusing, I swear. :ROFLMAO:
I dig it. I've never played the OG but if you like it, then this one should be an improvement. Depends on your gear but I think it sounds good.
Haha, it's a little bit to wrap my brain around but I get it thanks!
