Hello all,
I recently posted about this same pedal, but I'm making a new thread because I'm having a different issue with it. I recently got it fully assembled, but when the Distortion circuit is engaged the sound reduces in volume significantly, and crackles and pops. If I play a note hard enough, I'll get a sudden spike in the signal. The Boost circuit seems to be working okay, and signal gets through fine in bypass. I'm wondering whether there are any obvious places to start troubleshooting based on these symptoms, or if this issue is too vague to be diagnosed without further detail. Thanks in advance for any advice you might have!
Some pictures of the board (Note: Had to remove the J176 transistors for the moment to swap pins 2 and 3, so that's why they're sitting on the breadboard for now. Swapped them in for the PF5102s because I couldn't find any, but didn't realise until yesterday that the pinouts aren't the same. See my previous thread):
Video of the problem:
