I don't know that I have a need for publisherFrom their website;
"Check out just some of the brand-new features and major improvements below, including a new contour tool and select same in Affinity Designer, package output, data merge and PDF passthrough in Affinity Publisher, and the ability to add non-destructive liquify layers, path text and linked layers in Affinity Photo."
Sounds like it. I was just looking for the bundle![]()
Designer does do that. Each layer is preserved. Not sure if that’s newer functionality or not but I use Designer to export for Tayda now.Does anyone know if Affinity Publisher is able to export PDFs while preserving layers (thinking about Tayda UV printing requirements)? I know Designer can't do that, just wondering if adding Publisher to my toolset would bridge that gap.
Interesting, I tried it out with @SYLV9ST9R's help, and he couldn't see the layers when he imported the PDF onto Illustrator.Designer does do that. Each layer is preserved. Not sure if that’s newer functionality or not but I use Designer to export for Tayda now.
It's very possible that I only see the separate layers by re-opening the PDF with Designer. I'm not sure if it would work with Illustrator, I've never tried. But after a printing mishap with Tayda, I asked Hugo if the file was the cause of the issue and he said the files were good.Interesting, I tried it out with @SYLV9ST9R's help, and he couldn't see the layers when he imported the PDF onto Illustrator.
@Danbieranowski would you mind sharing your export settings? Thanks!
How Designer exports the layers is no matter how you "nest" the layers within each other, when Designer creates the PDF, it'll put those layers on the "base" layer list. For example, let's say I have a layer called "COLOR", and within that layer I have a second layer called "DRILL TEMPLATE". When I export that PDF, it will put COLOR and DRILL TEMPLATE in the layers list, rather than keeping DRILL TEMPLATE nested beneath the COLOR layer. This is obviously a 'no-go' for Tayda, as they only want the three layers they request. So to get around this, you have to make sure you don't use any layers other than those, and just use 'groups' within Designer when you want to group things together (like labels, drill template, etc.).
Here's a sample of my export settings:
I know oh too well what you mean!Might have to give it a try. Photoshop, GIMP, and what not always kick my ass.. Once I start learning, I end up not using it for a while and I forget what I learned.
Here is the official Start Guide, and they maintain a forum. Once you learn the basic terminology and how it relates to your goal, it should get you started. (at least, that's my plan)Are there any good ground-up tutorials for affinity?
