d3lay
manitsa7
hi i finished the d3lay but it has some ms delay,when i play something after some ms i hear it
it is something like if you monitor your guitar in daw and have some ms of delay when you play
anyone know whats happening?
You should not be getting a delay on your dry signal, if that is what you are talking about. You will get delay on the sounds going through the FV-1 chip. If you are only hearing everything coming through with some kind of delay, what happens when your mix pot is turned all the way toward the dry signal?
Can you show photos of the solder side of the board? If you are not getting dry signal, but are getting wet through it is most likely to be C2, R4 or R9. Try reflowing those joints and maybe adding a bit of solder.
you were right it was wrong value,i changed it and its working fine!
thank you!!
isnt it 100k too much for the volume pot?
it ads too much gain
I've built a handful of these, so I recognized the MLCCs there. As for the 100k volume pot, I don't find any issues with that at all. You don't have to set it to full on if it's too much volume, you can roll it back.
