I am only getting a dry signal with the pedal (engaged or off) and I checked the other posts but I am not finding my issue. My C8 is correct (although during assembly, I almost missed it!). I was poking around with an audio probe and noticed that the 78l05 was very hot. I measured incoming voltage at 8.2 volts (it's 9.1v at + on board) and the outgoing was 4.1v and slowly dropping. I replaced the power regulator and although it started getting hot, it initially gave me 4.96v out, but after about a minute,it started dropping as well. I unplugged the power after it dropped to 2.8v. I then tried replacing C23 but I'm getting the same results. Any suggestions on what to check next would be appreciated.
