griff10672 Active member Aug 2, 2019 #1 Build Docs call for a 5MM White LED .... anyone know if it's white diffused ???? or water clear white ???
Robert Reverse Engineer Aug 2, 2019 #2 Clear white. In the original it's not installed "pointing" at the LDR like we usually do. Install the LED flush against the board and point the LDR at the side of the LED.
griff10672 Active member Aug 2, 2019 #3 Robert said: Clear white. In the original it's not installed "pointing" at the LDR like we usually do. Install the LED flush against the board and point the LDR at the side of the LED. Click to expand... Well thank you very much !! That just saved me some troubleshooting I'm sure ....
Robert Reverse Engineer Aug 2, 2019 #4 It would probably have worked anyway, but I suspect it would have been much more sensitive with the LED pointing at the LDR.
