comradehoser
Built the Deofol for a second time for a friend with smd j201s. Have smd'ed successfully before (I think).
Sounds good-- very comparable to the first pedal, except that the distortion "grains" are a bit tighter with the smd j201s and the pedal sounds a bit more saturated than my first build with interfet through-hole j201s.
However, I am getting very strange volume swells across settings. This happens in my first build, but only if the voltage knob is set to 9:00 or lower, and the gains are set higher than noon. I am guessing maybe my smd skills are not so great after all, or it's a capacitor issue (?) or ... maybe the charge pump isn't right?
A strange event that may or not be related to this behavior: in a first for me, I managed to inadvertently fill a pad on C21 (10nf, lower right), and could not dislodge the solder for love or money with "heat-and-smack," more solder, more flux, solder sucker, or even pushing through a component leg. Could not get the cap leg through or extract it once it bonded with the solder, so I just left it after it tested positive for continuity. C21 looks like it is one of three caps wired to ground for the mids switch, so I fail to see how it would cause volume swells over the entire circuit.
