Erik S
Better late than never! I started working on this ages ago, but I forgot to order one part which pushed it back, and then I just started skipping over it. Once a project gets stuck in procrastination purgatory I have a hard time ever getting it going again. I was also pretty intimidated by the scope of it. Probably good that got a few more pedals under my belt before I started this.
There's some challenging stuff here - SMD parts, switched jacks, all kinds of pots to line up, and lots of wiring. The fact that I didn't screw anything up is mostly thanks to the excellent build doc @jjjimi84 and @benny_profane put together for this. Whatever questions I had, the answers were there.
I went for the "Alternate locations" for the mode switch, LED, and 9v through jack. I also implemented the mods listed here:
Because I knew there was going to be some flexing and stuffing involved, I went with stranded wire on this one. I hadn't used stranded in quite a while, and I don't know how you stranded guys do it. Lots of fighting with strands not going where I wanted them to.
I added the shrink tube on some of the bundles thinking it was going to make it look a little neater and help keep things together when I flipped it to solder, but doing that with single color wire was pretty dumb. Once they were bundled I had to use a meter to figure out what went where.
I've had a few different setups for late-night headphone jamming, but this is by far the slickest. Major props to @jjjimi84 and everyone who helped out with this - @cooder , @benny_profane , @Chuck D. Bones. Really cool project, and I'm glad I got to build one.
Here is the last Destiny Behemoth out of me for quite a while, I forgot how time consuming they are to make! This is in a 1590xx enclosure that gets taped off and then primed and then hydro dipped and clear coated. After the clear cot is nice and dry, the lettering and Cardinals logo was painted on there and clear coated. The led was a last minute position change but is a great addition. The circuit was tweaked according to this POST and is HIGHLY recommended.
These mods extend the range of the channels offering up a much wider range of tone. After finishing this one up, I went back...
- jjjimi84
- Forum: Build Reports
