Dielectric Boost - Tchula
Musicjsmith
A while back I found this circuit as a search for the Electra. It is simple and tweakable, but I decided to build it stock and then go from there.
The build documents are not complete so I used the schematic for the Je T’aime with just a couple values different.
It only has one knob so I used the hole pattern from the Cleaver boost circuit (or any other one knob build), but then I needed two switches. I used the pattern from the Dirt Dauber for that drill pattern. It all fits fine but there is not a ton of room for the switch wiring if you use a switch PCB.
Since it’s the Dielectric, I went with the local power lines in my neighborhood. I might switch out the know. I found an old knob off who knows what in my high school band room that looks about perfect. It’s just missing the set screw.
