G geoffrey Well-known member Jan 8, 2023 #1 Hello everyone! Another novice question: What kind of sockets do I use for socketing diodes and/or other two pin components? Thanks!
spi Well-known member Jan 8, 2023 #2 I use these: 40 Pin 2.54mm DIP SIP IC Sockets Adaptor Solder Type Lead Free - Get It Fast - Same Day Shipping www.taydaelectronics.com They're easy to trim to the size you need.
Synchrony Pedalworks Well-known member Jan 8, 2023 #3 geoffrey said: Hello everyone! Another novice question: What kind of sockets do I use for socketing diodes and/or other two pin components? Thanks! Click to expand... 30 Pin 2.54mm DIP SIP IC Sockets Adaptor Solder Type GTK - Get It Fast - Same Day Shipping www.taydaelectronics.com You can snip them for single to multi-socket use. In a pinch, I have used this to socket ICs or transistors.
Chuck D. Bones Circuit Wizard Jan 8, 2023 #5 You may have to crinkle the diode leads a bit to make them fit snugly in the sockets.
