jeffwhitfield
Ok, so I must be the King of finding weirdness with PCB boards.
So I got a Distortr and a CrackleJack and built a dual pedal out of them. CrackleJack turned out fine...but the Distortr didn't. Turns out that I got the order of the Gain and Subs switches wrong. I'm not good at desoldering switches (much less the rest of the components!) so I just opted to start over from scratch.
Second Distortr build was still problematic. I installed the wrong pots for Volume and Drive....or did I? The board itself was correct...but the documentation off the Distortr page shows the opposite orientation (with Drive on the left and Volume on the right). After flipping them back, both worked.
However, while the pots work, the switches don't. Subs switch doesn't seem to do much of anything. And the Gain switch does something..but I can't say it's a gain difference. Seems more like a tone difference. And yet the prior board is clearly wrong with the opposite switch placement. So...which is it? Which one gets the on-off-on?
I think the problem is that this particular PCB has seen a revision. The version shown in the documentation is Revision 08.20.17 and shows a pic of a PCB with a very different layout. The current one doesn't appear to be the same PCB. So, me thinks there might be an issue with the current board...possibly with the switches themselves. The rest seems to work...it's the switches that are the problem.
Kind of bummed.
Kind of bummed.
