Do you have a favourite pedal that you suspect nobody really knows about?
HamishR
Obviously we might have some home-brews that we think are the best ever (I do!) but do you have a pedal which you think needs more recognition? I have a couple of overdrives which I mention to people only to get blank looks. I guess there are just so many pedals around these days that some fantastic pedals will get overlooked and fade into obscurity - and that's probably a bit rough for the manufacturer.
My two overdrives of note are the Skreddy Hybrid Overdrive and the One Control Strawberry Red OD. A lot of players have heard of the Skreddy Screwdriver, P19 and Lunar Module but not many have heard of the Hybrid Overdrive. It's closely related to the Screwdriver but I think I like it even more. It uses a couple of silicon transistors and a single Ge transistor, hence Hybrid. It's a light to medium OD which breaks up a lot like a tight tweed amp or early Marshall. It has that magic amount of mids which give it a vocal quality for leads and perfect crunch and ring for chords. It has an extremely well voice tone pot which never gets nasty. I'm surprised it doesn't get more attention - it's a very natural sounding OD.
The One Control pedals don't get much press which is staggering to me because they are a high quality range of pedals. I've tried quite a few of the Bjorn Juhl designed mini-pedals and mostly they are excellent, but the one which really stands out for me is the Strawberry Red OD. It's a big sound for a little pedal. It has three knobs on top with a bass trimmer on the side although they are now making a four-knob version I believe. It's a tight, punchy sound which suits any guitar I plug into it. It kinda sounds like a very good boutique amp - it's that good! It can go from very low-gain grunt to more gain than I could ever use, and remains composed the whole time. It has a very lively, vocal sound which is addictive. It can really help fatten up a Strat better than most pedals without sounding clogged or artificial.
There are a host of "spin-off" designs from the Strawberry Red, but the original is still my favourite. The overdrive on my board is one of my own designs/ modified significantly from another pedal. But these two pedals mentioned above are still good enough for me to be reluctant to part with them.
What's your obscure favourite?
Grind Customs Ultra Stoner. They are out of business, but I found the build docs online and cobbled it together using an Aion Osiris board.
It was advertised as “the ultimate muff” and so far it’s my favorite version. (But there’s a billion muffs and they are all advertised as “the ultimate muff” :))
Thread '2x Muff: Aion Osiris + Grind Customs Ultrastoner'
https://forum.pedalpcb.com/threads/2x-muff-aion-osiris-grind-customs-ultrastoner.10649/
Creation Audio Holy Fire. I have one of the original, 48v models. (They still have a few at a great price.) The Transcendence here is based on their MK 3.24 (maybe not right, I consistently get those numbers wrong). Which is the clean gain part of the Holy Fire. There are Overdrive and Distortion controls (so you get G O D on the pedal, in keeping with their biblical theme).
Very clean gain along with a very amp like feel. Never added that much distortion, so can’t really comment, and don’t have much to compare it to in that regard.
I also have a Siegmund Micro Tube preamp that is no longer made, and other than the hassle of being AC powered, it’s very nice and has both a complete tone stack and a second higher gain stage.
Blackout Effectors Fubar Fuzz…
I love that pedal…
I like all their pedals but I especially love that one and never hear/see much about it…
I'm going to grab one of those Holy Fire pedals at some point.... but man, that MK4.23 was quite the task. :ROFLMAO:
I can loan you mine, as long as you don’t need to do much damage. No huge rush to get it back. It’s been off my board since I began making so many Overdrives lately😊, and I’d love to see what the circuit looks like anyway. They always touted its “computer” circuits…
If you get a chance pop the back off and snap a pic of what's inside.
If it's anything like the MK4.23 I wouldn't want to attempt to trace yours, they went above and beyond goop on that one.
The circuit was gooped and encased in a steel box... it was... intense. :ROFLMAO:
goop-png.10749
Good shout. I really miss the grind projects. Every single one I tried was stellar. I was particularly sad when they fizzled out. Also sucks that Juansolo and Cleggy moved on from the DIY scene.
I still have an ultra stoner, Ben Dover and some supernature boards left.
goop-png.10749
Gooping to that extreme seems very unchristlike for a bibble themed pedal company.
goop-png.10749
Rowland Research, who made (hell, they’re probably still in business) some of the top audio playback equipment, always potted their low current curcuit blocks and made them into plug in cards onto the larger chassis. This was done to deaden all vibrations and keep the components at a very stable temperature. They also custom machined their heat sinks (my 60 watt mono blocks weigh over 50 lbs each…) as a Fibonacci series to manage vibration…
But yes, in our pedal world, it’s paranoia. I’ll open it and send what it looks like—amazingly, there are a number of pedals I’ve never cracked open.
goop-png.10749
Ahh I see it has thermal stability, shielding from exterior heat sources, and resonance dampening for more focused sonic performance.
Okay, there is one potted area. I can try and take more close ups if it will help, including pulling the boards out—this was just for easy feasibility. The main board (double sided) is directly where the jacks connect, and the daughter board, at the switch, also Carrie’s the red and yellow array LEDs that go from yellow to red as the heat of the fire increases. (Or maybe just the signal gets stronger). A ribbon cable connects them both. Thee is the black block attached to the end of the switch board, (it may be an extension of the board, its hard to tell—there is a solid filet of solder where it hits the borad edge, looking just like the edge of a SMD heat sink. There are at least two visible S-08 chips on the main board near where the block block almost touches the main board. 8B4F75C4-34EB-4418-8365-F323BA858CDF.jpeg 53334E14-5428-4795-8ADC-4FC1EB2ADAE3.jpeg EA7E1381-A9F5-4ED7-B84D-A0BBBD4C8323.jpeg CB088500-6163-4452-8ACA-E52605C7B0A8.jpeg
