Locrian99
I’ve built several pedals but this is a little different than what I’ve done so I’m double checking i am right.
I have a very large pedal with smd components that’s doa. I think I’ve found the protection diode a sr24. Leaving it on the board I used the diode test function on my multimeter got 179. Data sheet shows forward voltage drop should be 0.5. Is this a bad diode then? I don’t want to do more damage taking it off will be my first smd soldering… which I’ll do I just want to double check I’m not barking up the wrong tree so to speak.
Thanks
Thanks
