Dual Seabed delay ?
I think my post 7 is still the cleanest implementation. You’d breake the signal path after R15 of each board and route those switches. I could draw it more clearly on the schematic.
In this case, in parallel mode, IC2.2 of the lower circuit mixes the three signals at once (dry, delay1, delay2).
I believe I understand what you mean. I am still waiting for a 4pdt toggle switch to show up, but until then I believe I will try breaking it at R15. If you turn the level all the way down on this circuit, it sounds extremely similar to bypassed. I will test doing this with all my other pedals that I use live to see if there's any side effects.
