Paradox916
Here is a question for those of you that program their own EEPROMs for the FV1, what programmer are you using? Anyone use the EZP20xx series and have had luck with it?
Nice, I was curious about the EZP20xx devices because it seems like a cheaper way than buying or building a dev board.I'm using the SpinSemi FV-1 Development Board. It connects to a PC via USB and I use the SpinASM interface to push patches in groups of 8 directly to the EEPROM on the FV-1 Dev Brd. I also have PedalPCB's "FV-1 Development PCB" and built it out, but I've not yet boxed or worked with it. The PedalPCB FV-1 Development PCB sales page has links to the instructions for 3 different OS platforms.
I also havre an EZP2019 EEPROM gizmo, but only use that to rip data from EEPROMs. I've never tried to push data to an EEPOM with it. So no help there.
Other folks have gotten a lot more mileage out of their EZP20xx devices than I have. I read posts where they use the EZP20xx for programming EEPROMs too. I just never got into that aspect of the device's software or full capabilities. Still, no matter device one uses fro programming an FV-1 EEPROM, it takes a good bit of reading and trial & error to sorting the ins and outs of pushing a bank of patches into an EEPROM. I just found that using the SpinASM interface and the SpinSemi FV-1 Dev Brd was the easiest manor to do so. It is however one of the more expensive ways. I just don't know HOW to get the EZP20xx device to push data into an EEPROM.Nice, I was curious about the EZP20xx devices because it seems like a cheaper way than buying or building a dev board.
Interesting, I wonder if asm and the EZP20xx is directly compatible.Other folks have gotten a lot more mileage out of their EZP20xx devices than I have. I read posts where they use the EZP20xx for programming EEPROMs too. I just never got into that aspect of the device's software or full capabilities. Still, no matter device one uses fro programming an FV-1 EEPROM, it takes a good bit of reading and trial & error to sorting the ins and outs of pushing a bank of patches into an EEPROM. I just found that using the SpinASM interface and the SpinSemi FV-1 Dev Brd was the easiest manor to do so. It is however one of the more expensive ways. I just don't know HOW to get the EZP20xx device to push data into an EEPROM.
Very cool that was another I was looking at, what software are you using with it?I use this cheap CH341a thing I got on amazon for all my EEPROM burning needs.
Did a like digging and this one is supposedly compatible with AS programmer. Seems like a good gamble.I use this cheap CH341a thing I got on amazon for all my EEPROM burning needs.
Yeah ASprogrammer is what I use for flashing. No frills, gets the job done.Did a like digging and this one is supposedly compatible with AS programmer. Seems like a good gamble.
I do not believe ASM and the EZP20xx are compatible. Nothing in the reading I've done indicated that.Interesting, I wonder if asm and the EZP20xx is directly compatible.
I couldn’t find any info on that ether, ( not that I looked too deep)I think this is a good conversation to have here, as I wasn’t finding too much on the subject pertaining exclusively to our use of the hardware and software, buiiding the dev board is a good idea as a second step but it’s an expensive endeavor for someone who has zero experience and want to get their feet wet with little monetary risk, There seems to be a fair amount of people playing with digital and coding, but there seems to be what feels like ether some unintentional gate keeping or lack of interest in answering questions , so hopefully this widens the path to seeing more activity in this arena. In short I wanted to say thanks for engaging in this and shedding some light on the subject as this is enabling me to chase the rabbit a little easier.I do not believe ASM and the EZP20xx are compatible. Nothing in the reading I've done indicated that.
It really breaks down to the following:I couldn’t find any info on that ether, ( not that I looked too deep)I think this is a good conversation to have here, as I wasn’t finding too much on the subject pertaining exclusively to our use of the hardware and software, buiiding the dev board is a good idea as a second step but it’s an expensive endeavor for someone who has zero experience and want to get their feet wet with little monetary risk, There seems to be a fair amount of people playing with digital and coding, but there seems to be what feels like ether some unintentional gate keeping or lack of interest in answering questions , so hopefully this widens the path to seeing more activity in this arena. In short I wanted to say thanks for engaging in this and shedding some light on the subject as this is enabling me to chase the rabbit a little easier.
Really good info, I have an inexpensive programmer coming, planning to start off by trying some patches off gut hub, once I have that down moving to spinCAD then try my hand at ASM.It really breaks down to the following:
1. No programmer other that the Spin dev board is compatible with the SpinASM s/w directly.
2. Any programmer that can read Intel HEX format files and is able to program 24LC32A EEPROM will work
3. From SpinASM you need to make a project (see PDF on making a project) with the programs you want to put in the EEPROM and make sure that the "IntelHEX" box is checked on the project dialog and click "Build" to make the hex file.
4. In the programming s/w that came with the programmer select the device as 24LC32A and read in the hex file built in step 3
5. After it burns the EEPROM put it in the circuit and test it.
As far as what cheap programmer to use, that is something you will have to research as they are changing all the time. As mentioned above the two requirements are it can read Intel HEX files (99% of programmer s/w can) and can write to a 24LC32A
I don't think it would hurt to try using the SpinASM interface to push to the EZP20xx device. Worst-case scenario is that it just won't work.I couldn’t find any info on that ether, ( not that I looked too deep)I think this is a good conversation to have here, as I wasn’t finding too much on the subject pertaining exclusively to our use of the hardware and software, buiiding the dev board is a good idea as a second step but it’s an expensive endeavor for someone who has zero experience and want to get their feet wet with little monetary risk, There seems to be a fair amount of people playing with digital and coding, but there seems to be what feels like ether some unintentional gate keeping or lack of interest in answering questions , so hopefully this widens the path to seeing more activity in this arena. In short I wanted to say thanks for engaging in this and shedding some light on the subject as this is enabling me to chase the rabbit a little easier.
Hey Cybercow,I'm using the SpinSemi FV-1 Development Board. It connects to a PC via USB and I use the SpinASM interface to push patches in groups of 8 directly to the EEPROM on the FV-1 Dev Brd. I also have PedalPCB's "FV-1 Development PCB" and built it out, but I've not yet boxed or worked with it. The PedalPCB FV-1 Development PCB sales page has links to the instructions for 3 different OS platforms.
I also havre an EZP2019 EEPROM gizmo, but only use that to rip data from EEPROMs. I've never tried to push data to an EEPOM with it. So no help there.G
Did you download the FV1Dev Bundle for macOS? The amount of reading required to achieve success is significant. There's a link buried on that Wiki page.Hey Cybercow,
So maybe it's my complete ignorance to coding (the extent of my experience is flashing a new OS to a piece of digital gear like a synth or pedal using SysEx Librarian but I certainly didn't write the code) but the "instructions" for the Dev Board being this page: (https://wiki.pedalpcb.com/wiki/Using_the_FV1Dev_on_Apple_macOS) might as well be a post-it note that says "figure it out yourself dummy"
I dont even know where to begin once the board is built. I have all the parts, the correct eprom chips and an imac running catalina. Any next steps or advice?
Anyone else feel free to chime in
I have climbed that mountain and have moved on to the next adventure, but this could still be helpful to someone else looking for an option. Thanks you for the contribution.I've used this successfully:
GitHub - hexeguitar/FV1_EEprog: FV1 EEPROM Programmer
FV1 EEPROM Programmer. Contribute to hexeguitar/FV1_EEprog development by creating an account on GitHub.github.com
HexeFX - 404
guitar, pedals, fx, digital, diy, electronics, flightsim, microcontrollerwww.hexefx.com
