SOLVED El Sol - crazy noise!
muffinscruffin
Hi all,
Like a lot of us I'm trying the El Sol for my first build. Like a LOT of us on the internet, I ran into a couple crazy noise issues, and I haven't really found them actually resolved anywhere on the internet. I'm also hoping to clean this up a lot because I'm hoping to build another for my friend's birthday next month!
I breadboard'd it, following the tutorial, and got crazy screeching noise out of my headphone amp, but the EL Sol sound nonetheless.
I figured it would work better on the PCB, so I tried soldering that up last night. Now I have the same exact symptoms...slow and weak signal, crazy feedback of noise and screeching.
I'm hoping when I put it in the aluminum enclosure it will fix the frequency interference but it seems like there are other issues at play here, and I don't want to start mounting if I still have soldering to do.
The issues:
-Sound doesn't come on immediately...seems like it has to "warm up" to start passing signal
-Huge noise floor when ON, with minimal guitar signal. I can hear the fuzz effect through the screen of noise at low levels
-Bypass seems weak and a little hissy too
-LED didn't come on
-When I plug a battery into my power jack (I have an adapter from my 1-spot power bank), I get reversed polarities at the jack??and can only get bypass signal
-The guitar's signal is so LOUD; by that I mean the sound of my single coils' background noise. There's obviously a ton of signal going through but not a lot of my sound.
I've tried:
-Changing power supplies: using a battery made it only pass sound in Bypass-maybe it's dead. Using my 1-spot grounded power supply helped the noise issue a lot, but didn't fix it
-Checking continuities from footswitch/board, and of grounds; I think I have it where I should, don't have it where I shouldn't. I do think this could be a problem area, those 3PDT switches are a doozy for a first-time solderer
-Different LM386N-4s, JRC386Ds; the Ds helped a little, now I'm using both, per recommendation I saw on this forum
-Cut LED off the board for now, ordered 3mms as opposed to 5mms? Seems like my 5 should have worked, Tayda didn't give me many options.
-Checking voltages/continuities of ICs...I'm getting 9.11V from pins 2->6 and ~8V from 3->6 (am I doing it right?)
-Ohming out the capacitors; Not really sure what I'm trying for here either, but 2 of my 10uf have wildly different values, and C3+C4 are showing no resistance at all. Is that normal for this circuit?
My 2 cents:
It's my first time soldering up a board and might have made some goofs. I don't see any burs or strands, but I also don't really have a fine tuned sense.
My Input and Output jacks seem to have some of my best solder work.
I can see I nicked a cap with my iron in one of the photos, that 10uf has the different value from the other.
I also hit the polyester film cap it looks like. I'm going to change the nicked 10uf. Should I change the film while I'm at it?
I'm also hoping I sourced the right parts. As a first-timer, I had a lot of questions and couldn't pull all my answers from Google.
I got almost everything from Tayda, the JRCs from Small Bear, and the LM386N-4s+sockets & silicon shielded/stranded 24awg from Amazon.
Are any of these components likely culprits for my noise problem? Does anyone have any fixes that haven't been shared yet?
Thanks for the help you all. Got it all re-soldered correctly and the thing CRANKS! Bypass mode works well too.
I burnt (barely) the casing of another 10uf in the process though. How sensitive are the electrolytic caps to heat? It seems to still be sounding good, until I get over 80% on the pot. Then the background "beeeeep bwoops" come in. It is all still exposed on the floothough, and was ,making on/off connections with my pedalboard's metal.
Thanks for all the tips too. This being my first project, I knew what to do, technically, but kept being sloppy bout my wiping/tinning, and was working with a handicap with my tools.
This iron is a 25W and the chisel tip is old and scrappy. I had it lying around and was thinking about getting another tip for it, but I'm thinking I should get a whole new kit. 25W is supposed to be able to get up to 900F I think, but my iron is definitely making it harder than it needs to be.
Reactions: Nic
Reading back through old threads. Not sure if you've picked up a new soldering iron/station yet. If not, then I'd really encourage you to go higher than 25w - it's not just about the temperature it can achieve, but also about the temperature it can maintain while you're working and cleaning and re-tinning. In my experience. A more consistent iron temp (with a clean tip) is going to translate into more consistent solder joints. I have also learned that you CAN have too much heat for the job lol. Ask me how 😂
