Mentaltossflycoon
- Build Rating
- 5.00 star(s)
I've long had a hankering for an expression controlled lpf. This here very much fills that void and so much more. I kind of expected to mostly use this in expression mode. I have used the subpar lpf on my e.h. hog a lot and the filter fx is much smoother. The sweep is more natural however with the filter wide open it is still a pretty drastic tonal change from the bypass tone so I wouldn't consider this an "always on" or utility lpf, or hpf for that matter. Something like a broughton would be the way to go there. This is a fun time filter for making the fun sounds. The waveforms are all great, including the bleep bleep boop boops. I didn't think I needed a sawtooth lpf but yep, now I do.
I only have 2 complaints with the design: side jacks and that obvious tonal shift when turned on i just mentioned, which I only point out because it's the only way in which the eh hog lpf is "better" being a bit more subtle when engaged.
So you crank down the depth to use the expression. If I end up using this regularly in lfo mode, I'll probably put a 2knobjob on the depth pot. I left room for another footswitch if it comes to that. It'll be way too crowded but I'm a pedalboard ballerina. Might put the rate pot on an expression jack too.... tap tempo is totally unnecessary for me but it makes me feel fancy.
As per always, I couldn't let the side jacks happen if I could help it so I flipped it sideways, squareplug ftw! This'll be backrow so the cabling won't be a problem and can hang down a bit.
