jrbell1990
Hi all,
Built up an Electrovibe for my father in law. Sounds great but there's an issue when re-engaging the effect that I can't quite solve as of yet.
I can email a video of my issues to anyone interested as the minute-long video won't post to Imgur or here.
First and most importantly, the sound cuts out for 2-3 seconds after turning it off then on again. So far I have changed the charge pump, foot switch, input, and output jack wiring. I am getting continuity from the foot switch to the board just fine.
Second and possibly related issue, the status LED remains dimly lit when the unit is off.
I went through the mod thread and only implemented the unity gain mod after installing the resistor it called for in the build sheet.
The odd things I have had to do to make this board work include wiring the lamp regulator on the opposite side of the board and inversing the orientation. I also have fly-by-wire dual gang pots on the speed controls. I have insulated as many potential shorts as possible, but I imagine there still could be one present causing this audio issue.
Thank you for any help.
