Electrovibe - Bizarre issue.
nkt$275
This is my second Electrovibe build.
First one works perfectly. Wonderful !
Second Electrovibe problem -
Sounds incredible BUT - When the guitar jack and amp jack are mounted in place to the metal enclosure this issue occurs: On both speeds going below 9:30 the vibe effect stops and the mod speed LED goes solid. When I unscrew both guitar jack and amp jack place them so they are not touching the metal enclosure the vibe works perfectly. 9:30 like the face of a clock … the slower rate settings.
The difference between build 1 and 2 is Electrovibe 1 uses the foot switch boards. Electrovibe 2 foot switches are wired to main board. I tried disconnecting ground wire from mod rate LED but still had the problem.
Help much appreciated !
Oh Yeah! Heat shrink tubing.
I left it flat so it is double.
The fix happened a couple days ago but I wanted to let the paint dry before I put it all together.
Tuff lesson!
