kleinbergerzam
Having an issue with my ElectroVibe build. Bypassed sound comes through but is still effected by the volume control. Meaning if I turn down the volume completely I get no signal through the pedal in bypassed mode.
The effected signal works and the sound is great. All controls act as expected. But, I get a ton of radio interference. This gets worse if I touch the top of the C5 capacitor. Going anywhere near that area with my hand causes the noise to increase.
I have sanded the inside of the enclosure to make sure that everything that should be grounded is. I have double checked all of the soldering joints and made sure the speed pots are isolated from the board. I also used shielded wire for the input and output wires.
The radio interface can be heard in both bypass and engaged mode. I’m using a really nice Walrus audio power supply and have many other pedals I’ve built powered by it and none have this grounding issue.
Maybe the circuit isn’t completely bypassed? I’m using the switch board that came with the board. Feeling stumped and have had the board in and out of the enclosure a few times trying to track down the issue.
