Enclosure Grounding Techniques
I tried the keystone spring thing for a while but could never get good contact. Even without powdercoat overspray, aluminum forms a thin layer of nonconductive oxide very quickly and sanding/scraping/brass brushing the inside of the enclosure just leaves a sometimes-conductive mess of shavings.
I ended up with a ring terminal on the footswitch sandwiched under the star washer. I also got some chonky external-toothed star washers. I've added an extra through-hole on my footswitch daughterboard to connect the wire from the ring terminal but of course you can just bodge that wire to the footswitch ground terminal too.
Tightening those suckers down bites though the aluminum oxide layer (and even a little bit of powdercoat overspray) and the pressure keeps the oxide layer from forming.
I especially needed this when switching to the plastic 'innie' style jacks where you screw the nut/sleeve in from outside the enclosure so you can solder the audio jacks right to the main board.
What is the issue with just grounding via the jacks? Does that cause some kind of problem?
  • Like
Reactions: spi
I don't like the springs either - they don't look that secure. I'm thinking it may be worth it to take the time to solder a wire to a ring terminal and sandwich the ring under a pot or the footswitch.
I'm using the neutrik style jacks that have a plastic external nut and don't ground to chassis
What's your favorite non-audio jack related way to ground your enclosure?
The Keystone spring or the cliff audio jack surround thing? Or soldering a wire to one of the serrated washers that comes with the blue footswitch?
Any other options?
I just tried soldering a ground wire to typical guitar shielding copper foil with conductive adhesive for what I expect to be a short lived prototype pedal. It metered out at 1 ohm including my Fluke test leads, which will work fine for my use case.
Any other options?
i just use sandpaper on the inside of the enclosure to get rid of any stray paint even if the inside of the case looks bare.. because clear coat is still paint and i watched it happen on my own first build :p
then I use the lock washers on the inside of the case for everything.
also, every jack's ground lug goes to a board ground pad. i don't trust mechanical connections to do jack grounding, those loosen over time even with the lock washer
I think people have a problem with it because of the whole paint-as-an-insulator or the jack-wasn't-tight-enough thing.
