Equilux Mini and Swarm
ftumch
5.00 star(s)
Finished these up. Pre-drilled enclosures from Tayda, then waterslide decals and clear coat
Had a bit of trouble with the Swarm - ordered a CD40174BE instead of a CD4017BE. Don't do that lol. Assembly was very easy with header pins
The name is a play on circle of fifths. The sounds this thing produces makes a mockery of the word 'harmonising' lol. Pure filth
PXL_20250604_171613789.jpg PXL_20250604_172104075.jpg PXL_20250604_003500564.MP.jpg
Used the Equilux Mini at a rehearsal last night, it works really well on guitar to bring out the upper mids and cut the flub. Will likely replace my parametric with this cos it's easier to use. I plan to make a couple more of these with low tolerance WIMA caps in the filter sections:
PXL_20250604_171556417.jpg PXL_20250604_172304618.jpg PXL_20250604_172316281.jpg PXL_20250603_163534066.jpg
The water slide decals look good! Did you clear coat the enclosures before applying the decals, or did you apply them directly to the bare enclosure?
