Hi friends,
I have an Eternal Burst in a dual overdrive project with a boost in the front of the pedal. The boost works and the guitar comes through the amp when both effects are bypassed, but im not getting signal when the Eternal Burst is switched on. Turning the 3 knobs do have an effect on the background noise that I can hear, where when all 3 are maxed out there is a low volume oscillating sound that can be "tuned" by the tone knob. BUT get this: I can get sound when I crank the boost into the eternal burst and crank the eternal burst's volume & gain. Its not loud--about the same volume if I rolled my guitar's volume to "3". Unfortunately I boxed before I rocked... so I'll have to come back to you all with pictures of the underside. I do clean my boards and inspect solder joints before wiring up. I will include a picture of the topside of course.
I believe that Im getting the correct voltages on the IC: (values +/- 0.25)
1 - 3.5
2 - 3.5
3 - 3.5
4 - 0
5 - 3.5
6 - 3.5
7 - 3.5
8 - 9v
I tried with A NJM4558 and still didn't work
Diodes and Electrolytics appear to be in the correct orientation, agreed? I checked the resistors and they all appear to be the correct value. Bottom of board not touching back of the pots (I raised it up and insulated to make sure). This doesn't have to do with me not wiring up the LED, does it?
Excited to hear back from you all! And I'll get pictures of the underside . Happy Halloween!
1 - 3.5
2 - 3.5
3 - 3.5
4 - 0
5 - 3.5
6 - 3.5
7 - 3.5
8 - 9v
